JIm tried to put this into "Free resources" doesn't look like I can
Thanks Alex, I'll load it in, in the future you can also just add a hashtag #financing and that allows anyone to find it if they search.
Bot it. read it. great read and really simple, but helpful breakdown of the capital stack.
Picked this up too- very useful read.
