Thanks for sharing! I am a ULI member and considered attending the Fall Meeting. I'll plan to attend the next one. These are interesting discussions.
Agree Lasenta - super interesting discussions. And thanks for sharing, Chuk! I am a new-again ULI member (was a member a few years ago) and also plan to attend the next event. Hopefully NYC in the Spring. 🤞🏻
