5 Small Housing Lessons
๐
This week I had the opportunity to keynote ULI Atlanta's annual Housing Innovation Summit. The theme of the program focused on smaller interventions, so it was a great opportunity to share both the promise, and ongoing challenges of Building Small. Here is a short synopsis of the 5 lessons I shared.
- Zoning is just the beginning
- The Conversation Cannot Start with Your Project
- Its bigger than Affordability
- Form matters more than lot size (or shape)
- More Thought Partners, Fewer Administrators
Zoning - while there is a lot of energy and great progress being made changing zoning codes, it is just the tip of the iceberg if we are going to truly see effective and scaled missing middle housing infill out comes. Sure it might allow large projects in the green fields to build a lot of MMH, the but the promise of the missing middle story is to create surgical infill projects that will intensify neighborhoods, add more diverse housing options and create equity ladders for people to buy smaller units and grow wealth. The list of what else has to happen before THIS becomes a reality is very long and proponents need to make sure they are championing this as loudly as they are zoning.
Conversation - I usually preface my presentations on RiverHouse with a slide that shows the outcome from community workshops that demonstrated what our hometown wanted in terms of new housing projects. This was a conversation facilitated and started by the City, not by me as developer. I just rode in on the heels of that conversation and was able to say 'you all said you wanted more cottage courts....now how do we work together to deliver one'. By laying the groundwork for this housing typology, the community was already aligned, and anxious for someone to demonstrate the potential. It made my life a lot easier.
Affordability vs Diversity - there are so many programs, funding mechanisms, industry 'hacks' all focused on housing affordability. And while this is important, people are not talking as much about housing diversity. With less than 25% of today's households being the standard 2 parents and 2 kids, having a variety of housing options - regardless of what they cost - needs to be an important part of any housing conversation.
Form vs Size - most codes that focus on single family housing set lot size minimums. Square feet. Side yard and front yard setbacks. Minimum width and length. And so the process of building neighborhoods typically start with an engineer laying out lots to conform to these standards and then a builder picks their most successful product and places it on the lot. There is no consideration for how all those homes fit together to create a complete composition - it's just a process of solving for code minimums and re using a template product. At RiverHouse we did the opposite. We laid out the homes to create the kind of urban form we wanted and then backed into the lots. And what resulted was very gerrymandered, and something most regulators would never approve. But because our public works director understood the goal (and the community had expressed this is what they wanted - see #2), they made it work.
Thought Partner not Administrators - which leads to my last point. The reason this project came to be was not because we have changed the codes, or adopted some new form of zoning du jour. it was because the people in the planning department were invited to be thought partners on the project, not just administer the code. By starting with early conversations of options, and implications, they had a sense of authorship in the outcome and a sense of what could be accomplished if we worked together, rather than just checked the boxes.
๐
15โค๏ธ
๐
๐ก
๐
๐
Explore More Posts
At SDF#25 in Greenville, the first question we asked the room was simple. What is your biggest current Small project challenge? That's what our community of practice is about - asking what's working and what isn't and then find solutions together. Finding a deal that will pencil and raising project capital were the top two. Local government or neighborhood resistance was lower in the lineup, which I take as a hopeful sign progress is being made. That lines up with something I said on MIT's podcast last month. When I wrote Building Small, the two big barriers were regulation and capital. Regulation is easing - by mandate or common sense. It's not there yet, but there is movement. Capital is still the biggest challenge for small developers trying to get started. That's why we started Path-to-Capital, a new Building Small program that was unveiled in Greenville. For projects too small for the big guys and too big for the country club crowd.You can learn more at our Path to Capital inquiry form. https://form.jotform.com/BuildingSmall26/learn-about-path-to-capital-in-2027
SDF#25 was full of excitement, camaraderie and connection. And with that zeitgeist it was the perfect time to invite our attendees that had not yet signed up, to become part of the movement that is Building Small. Welcome to our newest members, as they help us grow our community of practice, driven to help small scale developers succeed. Welcome to our new(est) Charter Small PROs!Aaron OrensteinBlake ComptonChris WarrenJim GillespieMatt TeresiRob LanphearShareil EliaYang Zhang And our new(set) Small Builders!Alex VartanAndrea Van SoestDave MadanDennis HolsteEmily IsenbergJeff SlajerJim BlackstockJonathan HuckJohn HillmanKelli WilderLasenta Lewis-EllisMarsi Puente-CarterOdeidra WilliamsPatryce CampbellRobert MulcahyYolanda Claudio
