Hi Hannah - two names come to mind - Eve Picker of SmallChange.co for potential financing speaker. Chuck Durrett of The Cohousing Company might be good for the second question, but not sure what you mean by ʻadding density or affordabilityʻ.
Hi Zannah,
My name is Jesse Russell — I own and operate Hiatus Homes here in Bend, Oregon. My partner Ryan Andrews and I also run a local …more
